The motor will start easily (1-3 pulls) and runs good at low RPM and high RPM. When I run at WOT for 5-10 minutes though, and shut the engine down for a few minutes, I can't get it restarted. No matter how many pulls. If I wait a few hours though, then I can restart it no problem.
Any Ideas what the problem may be? I am completely stumped!!!
HISTORY OF THE MOTOR:
1992 - Johnson 9.9 Long Shaft
I just installed a higher capacity fuel pump kit (standard after 1993 on this motor), new fuel hoses, rebuilt the carb, new spark plugs, adjusted the throttle linkage and cam adjustment, and am using a brand new OEM fuel hose & bulb. Also last year I did the water pump.
The engine runs pretty cool (i.e. block never gets hot enough to burn you). The water tell-tale pees a solid stream.
One of my questions is generally how many turns is typical to adjust the mixture adjustment knob on the carb (needle valve)? After seating gently I have tried adjustments between 3.75 turns out, and 6.25 turns out. Any suggestions here? I have seen minimal impact on engine performance.
