f_inscreenname
- Aug 23, 2001
- 2,591
I have a 19'boat with a chrysler 360 with a volvo 270 outdrive.At diffrent RPM levels (1200 to 1400 and 3200 to 3800) I get a vibration thru the hull. More herd not realy felt but humm....humm....humm...humm... I have had many boats and they didnt do that (I must admit they were outboards or mercruisers). Everything is new. The motor complete rebuild and balanced. Had a problem with the pilot bearing,the crank was never drilled for one so I ground a bearing down to fit the hole that was there (dont ask how I did it but I think it came out right. The bell housing shaft sliped right in. No resistance at all).Motor was just installed.A couple of people said to line up the motor you must line up the tabs on the bell housing and on the transom shield but there isnt any on mine I have 2 bell housings and the second one dosent have tabs eather. So I measured from the stringer to the top of the exhust mani. Is there a better way? The bell housing on the boat was completly rebuilt. New U-joints in the outdrive. New bushings in the pins that hold the outdrive to the shield. I dont know what else to do. Is this normal? Like I said I had a few boats and they have never did this. noticable
