We just bought a 89 Checkmate Spectra 200 w/87 Johnson GT200 from orig. purchaser, it is as new. He said he never adjusted the motor hieght and bolts look like they were not touched, problem is it cavitates very easy in corners or if someone is in bow section. Looks like cavitaion plate is above lowest point of rear hull "raining right now or I would check how much" tried 2 props, 1 raker 14.5 x 22 stainless and 1 14.25 x 21 alum. Aluminum seemed better? Motor can be lowered approx. 1.5-2" with one hole, or is there a better prop? had Stiletto on last boat and it helped stop cavitation, 4 blade prop help? thanks for any info
