motor tilt noise
dooge
1987 evinrude 150 when trimming motor its so loud you cant hear someone talking from front of boat. as far as lifting or lowering it does fine just loud
boatmec04
Re: motor tilt noise
Check the fluid level in the pump.You might need to add more to it.If it's low check all the seals on the pump or ramb for leaks.If there is leaks you might want to replace the seal or seals first then fill.Make sure you purge all air out of system or it will still make noise. HOPE this helps keep us posted.
