Motor Swap...
cjf2848
Hello. I'm new to here so please bear with me if you've heard some of this before. I recently switched out a 4cyl merc with a straight 6 merc. Couple of questions here. First, I canot find the serial # on the straight 6. By the looks of it, i would guess late 60's early 70's, and it has the old wire colors for the harness. I switched the harness over( by this i mean i had to cut the plug off the newer 4 cyl. and wire it into the old harness) and everything seems to work fine but my tach reads 3000 at idle and buries it at any over half throttle. So these are my two questions, how can I find year of new engine I put in and what could possibly be the prob with my tach. Any help appreciated. Thanks.....:D
imported_TheMan
Re: Motor Swap...
When switching engines you have to recalibrate the tach. There is usually a switch on the back for 4, 6, and 8 cylinder engines. You will also have to use a separate tachometer to calibrate it.
I'm not aware of a manual to do this, so I would suggest you take out your tach and examine it. Then you can play with the calibration till you have it set right.
