motor support
83deck15ft
motor support is stuck it wont let me put my motor down i trimed it all the way up and tryed to put the motor support down some one help
5150abf
Re: motor support
There should be a screw head on the body of the pump that will let you lower that down again, the last one I saw was on the starboard(right) side of the pump but it is on there somewhere.
Turn it slow as you aren't sure how fast it will drop.
F_R
Re: motor support
So, you are saying it is tilted all the way up and sitting on the trail lock and you can't move the trail lock out of the way to lower the motor....is that correct?
If that is the situation, you have to tilt it up a bit more to be able to release the trail lock. Then it will be able to tilt down.
