floatfan
- Feb 28, 2011
- 184
I did some maintenance on my little boat which hadn't seen the water in a couple of years. 1980/81 Merc 9.8. I cleaned the carbs and replaced the gaskets, as well as replacing the water pump impeller. Also replaced the fuel lines with the new blue hoses and installed a new primer bulb due to the old one being stiff. At the river Saturday, the boat motor was running like a top, but after a minute or so, depending on the throttle, would seemingly run out of fuel and die. I noticed that while running, the primer bulb didn't seem like it was full. I ended up driving with the tiller in one hand and the primer bulb in the other, and about every 15 seconds would pump it. No problems as long as I did this. What could cause the lack of draw in my fuel line?
