Re: Motor Smoking
I assume that your motor is a 2 stroke. If this is so, my experience with outboards confirms that cold start-up's with heavy smoke in the exhaust is normal. As the motor warms up to operating temperatures the smoke is not as heavy. If your motor is tuned properly and the carbs are set correctly (air/fuel mix) your smoke density should follow this pattern. Of course i have seen motors with piston ring wear or faulty reeds that will make heavy smoke regardless of the time the motor has run. My2centsworth.com......lol
