Re: motor size for 14'
Hi CA. Welcome to iboats. The 35 hp max sounds about right for a 14' boat. However, bear in mind that most capacity plates assume you're using a 2-stroke engine which tend to weigh quite a bit less than their 4-strokes cousins. For example, my 1966 20 hp 2-stroke only weighs about 80-90 lbs, whereas the 20hp you described is quite a bit more and may well be a 4-stroke. If you can post a bit more info on the motor we can be sure. Depending on the layout in your boat, you'll also need to factor in your own body weight and any gear that your store in the stern (rear) of the boat. It sounds like your total weight is under the 1000 lbs. max so the trick will be distributing it evenly within the boat, which just takes trial and error.
