1988 force 125 ran it today, motor kept running and it rev up...turn the key to off and pull key out did not stop.pull stop switch did not stop.had to cut fuel line to stop motor.
trouble shoot problem...still lost.
ignition wiring and color...S-yellow,C-green,B-red,M-white & a wire going to stop switch,I-empty,M-the one wire going to stop switch.
there is a blue wire not hook up.
terminal block reads
Y-starter
P-tach
W-magneto
G-choke
O-heat
R-bat.+
B-magneto
BLK-ground-
question??? is the stop switch supposed to be hook up on the 2 M's on the ignition switch.
how bout the blue wire thats hanging is that supposed to be hook up on one of the M on the ignition.
question??? how does a kill switch work.
thanks guys...
Y-starter
P-tach
W-magneto
G-choke
O-heat
R-bat.+
B-magneto
BLK-ground-
thanks guys...
