motor oil from carborator
j.p.h.
what causes this? driping oil aside from old age i beleive this is a 1984 35 hp evinrude
MTboatguy
Sounds like you might have your fuel mixture to rich, what ratio are you running? Old carbs do leak, but normally I don't get oil out of them. It is unfortunate, I don't consider an 84 to be that old!
:eek:
j.p.h.
im using a standered 50 to 1 oil ratio but geting oil build up wich slowly runs down side of motor over time. it drains out of the carborator and works itself down realy appreciate your input many thanks
j.p.h.
what is a good normall compression ratio for an older motor? about a 1984 35 evinrude
sutor623
Depends if it is pull start or electric start. Consistency amongst cylinders is more reliable, but if it is a rope start Id say 75-100psi would be normal. Electric start 100-130 in both cylinders.
The oil leakage is strange because typically once you mix the fuel and oil they dont tend to separate. Can you send us a pic?
