I have a 1990 Nitro Bass boat that I'm going to be mounting a 78 Mercury V6 outboard on. The mounting bracket has a more narrow bolt pattern than what my transom will accomodate so I'll have to plug the existing holes and drill new ones. The bracket is also deeper than the stock one was, so the bottom hangs down about an inch or so from the bottom of the transom. I've tried to attach a couple pics, hopefully it works.
As you can (hopefully) see, the transom steps down a couple of times before it reaches the bottom of the boat. The bracket will hang down about an inch below the first step down. Is this a problem?
