How do you measure a transom to determine if you need a 20" or 25" shaft?Thanks,Timb
T tbjtib Seaman Apprentice Joined Apr 3, 2002 Messages 31 Jun 8, 2003 #1 How do you measure a transom to determine if you need a 20" or 25" shaft?Thanks,Timb
D digimortal777 Petty Officer 1st Class Joined Jun 25, 2002 Messages 214 Jun 8, 2003 #2 Re: Motor length with a measuring tape
K Kenny Bush Chief Petty Officer Joined Mar 24, 2002 Messages 564 Jun 9, 2003 #3 Re: Motor length Measure from the top of the transom(where motor hangs on), to the bottom of the keel(V). If you have a stepped/notched transom pad, it will be slightly different. Oh and as stated earlier, you use a tape measure.
