Hello,
I recently acquired a Johnson 40 HP Electric Seahorse outboard, Model# RDS-28, Serial# 2166453...and would like to know a bit more about it (year it was made, and how it compares to other similar motors in the line).
What I do have, that is functional and reliable (though missing some parts, that I'd like to cannibalize from the new, nonworking compression-less Johnson) is a 1964 Evinrude Big Twin 40 HP (that the folks here were so helful in getting it up and running).
What I'd like to know, is what is (or definately is not) interchangeable between the two, since at first glance they look similar.
Specifically, the parts I'd want from the Johnson are as follows:
the electric starter, starter bracket, and toothed ring gear (as my motor currently doesn't have those).
possibly the head w/ spark plug holes (mine currently is holding compression despite rthread inserts on both plug holes...though the donor Johnson looks almost like it has mechanical lifters or something, as there is a spring loaded protrusion adjacent to each plug hole, plus a bracket that swings to mae contact w/ them, that has a threaded end adjustment...what else connects to this rod is unknown and missing).
last set of parts would be the propeller and foot housing that coverls the lower gears (also the clutch dog, as well as any other miscellaneous lower unit gearing and parts would be nice as spares on hand).
Thanks for any help and suggestions
(the "donor" Johnson has been setting on the ground sideways for the last decade, and the owner previous to that never heard it run either...the flywheel turns quite easily w/ no resistance when in neutral, therefore seemingly no compression, and my inexperience suggests possibly a blown gasket, broken ring, damaged valve, or something bigger/worse).
(also, when put in any gear, it's the same scenario, everything just spins way too easily, plus the plate under the flywheel w/ the points on it looks super wobbly...my thinking is that it's likely something fairly catastrophic happened way back when and took some internals out...but any tips on what to look for would be great...cosmetically, it's sure alot nicer than what I've got running, but at least my ugly motors still going).
