Had the boat out today...Ran just about flawlessly after Changing power pack and rebuilding carbs. <br /><br />My next goal will be getting the boat/motor set up correctly. My AV plate sits about 2 1/2"-3" below the bottom of the transom. WOT produces 4700-4800 rpm @ 34mph(GPS). <br /><br />I know I can get more from this motor...just not sure how. Compression is just over 115 on all cylinders and Current prop is a Michigan SS 13 1/4x17. <br /><br />My goal is 5800 rpm, do you think moving the motor up 3" will get me there. Also, what kind of speed should I expect @5800.<br /><br />Thanks for the help,
