Timberwolf17044
- Mar 20, 2011
- 53
Ok guys and gals here we go. Attached are a few pictures to provide a visual of what I'm explaining. I have a very old 12' 8" fiberglass boat with a 1980 Johnson 9.9 long shaft recently converted over to a short shaft. When I was using the motor on this boat prior to conversion I had made a jack plate to lift the motor. After conversion to the short shaft I did the research and everything I read told me that the cavitation plate should be even to 1" or so above the bottom of the boat. As you can see in the images the cav plate now sits about 2 inches above the bottom of the boat, a miscalculation on my part when I cut the jack plate down after converting it. I took the boat out on a local river on Saturday and was very disappointed in the boats performance. I had about a 75 lb bag of concrete mix up front to help hold the front end down and at full throttle could not get on plane. Even worse was downstream. My question is, will lowering the motor another two inches have much impact on the boats performance? Thanks in advance for all your help.
![2011-06-13_21-02-52_780[1].jpg 2011-06-13_21-02-52_780[1].jpg](https://forums.iboats.com/data/attachments/84/84756-49e7c6940a180485681958dca336bf82.jpg)
![2011-06-13_21-03-29_816[1].jpg 2011-06-13_21-03-29_816[1].jpg](https://forums.iboats.com/data/attachments/84/84757-07ed0ef67f0dd31093fb9a639738895d.jpg)
![2011-06-13_21-28-09_893[1].jpg 2011-06-13_21-28-09_893[1].jpg](https://forums.iboats.com/data/attachments/84/84758-e97fd083b01cccb584f5078e964c46f5.jpg)
![2011-06-13_21-02-38_511[1].jpg 2011-06-13_21-02-38_511[1].jpg](https://forums.iboats.com/data/attachments/84/84759-da6d6c545a58eadc18fc3e2d0877c5f4.jpg)
