motor guide 2400
Status
Not open for further replies.
crb478
I recently picked up a used motor guide 2400 bow mount in good condition, but it does not have the thrust lbs listed on the trolling motor. Does anyone know how many lbs of thrust it has? I can not find it on their web site, but the prop appears to be for a 41 to 45 lb. It is a 12 V unit. Thanks
jtexas
Re: motor guide 2400
try mikesreelrepair.com click on schematics drill down to motorguide
couple more T/M sites:
crowleymarine.com
trollingmotorparts.com
crb478
JTEXAS and TD thanks for the post, I am still comming up empty, but at this point I have bought it. I will put it on a boat sometime and see how well it works and gauge its size that way. thanks again.
abrahamkou
I just got this motor for $40. I measured it, it draws only about 4.5 ampere at 12Vdc. or 54Watts. Google says 1HP = 750 Watts. So it only has a pathetic 0.07 HP, or about 6 lb trust.
jbcurt00
Start a topic about your motor if you have questions
Closed
Status
