Re: Motor Flushing
I assume you're flushing at season end, as it makes no sense to flush after each use. At season end, I tilt my 1983 J75 up, put a plastic barrel in place and lower the engine. Fill barrel leaving hose on in barrel, and run for as long as you like, doing whatever you do to de-commission. <br /><br />After each use, merely let it idle for a while to cool down, then leave in upright position. All OBs are self-draining in the vertical position.
