Re: Motor dies when the engine cover is put on.
OK, guys, first the seal doesn't come with the water pump kit. When you threw away the old housing, you threw away the seal too. It's a special seal, unlike anything else on the market. It's worth a try to see if Sea-Way Marine has any of them.
http://www.sea-way.com/index If the seal is not in there, you have found at least half of the problem, maybe all of it. Yes the smoke comes up from a hole out of sight in the front of the exhaust housing, near where the shifter goes down.
In dealing with motors that run in boxes on sailboats, I have tried a number of snorkle schemes. Never had any success. But what have you to lose? Except a hole in the hood.
The shift rod boot is above the plate that you see if you look up where the shift rod and water tube disappear into the exhaust housing from below. You can't see the boot from below. Don't be removing the plate unless you have a new boot.
If anybody wants to try my solution to a torn shift rod boot, e-mail me at
gatorsnfrogs@verizon.net and we can talk about it.
