Hello again,<br />We rebuilt the low end, put new hoses on fuel pump, cleaned out carb. with cleaner, drained gas tank and put fresh gas/oil in 40-1. Ran it in a tub and it did fine except I had to prime the carb with gas/oil mixture to start it. Took my two boys and self to the docks, launched it, so far so good, Traveling 5mph to get out into the open lake area, went to throtle up and would not go any faster then 2000 at most, we were cralling. Motor is a 1966 Johnson v-4 60 hp on a 1963 crestliner 14'-0". We were out for about 50 minutes, we were just cralling and I didn't have it WOT, when all of a sudden it kicked into a low rpm for about 10 seconds and stalled. Observations were, the primer bulb from the gas tank was soft, I primed it several times and nothing, not even a hint that it wanted to start. When I had it on shore I took the hose line off the carb and turned it over and gas was coming out, it wasn't shooting out just little sperts. This just happened yesterday so I haven't had time to try and start it since it was in the water. I took the plugs out and two where dark and wet, the other two were dry and white. What does that mean, running Lean??? The fuel pump and the carb have not been rebuilt, I was waiting for the winter to do this. Compression is 92-92-100-93 psi with a sears guage. Can anyone help on this one? Thank you in advance.<br />Mike and son Zach<br />Still digging it, but it's getting cool out there!!
