Re: Motor Corrosion or oxidation?
The white stuff is Aluminum Oxide. It is caused by stainless steel and conductive water. You do not need salty water for galvanic corrosion. I have seen engines get it from parking under a pine tree. The pine sap contains enough acid to make the rain water runoff conductive. There are also some lakes in Texas and Oklahoma that have enough minerals in them to cause galvanic corrosion. High amounts of pollution can cause same thing. All you need is water that conducts. There is a galvanic chart. In general, soft metals are at one end and hard metals are at the other. The further apart the metals are then the more strongly they react. Aluminum is considered very low, less than copper. Iron is middle high. Nickle is very high. Stainless 316 is very high. The more stainless you have on your engine then the more aggressively the aluminum is attacked. The ideal engine would be all aluminum and non-metalic composites. However, aluminum just isn't strong enough for bolts & stuff so you are forced to use iron, steel, and stainless. Keep your anodes healthy to minimize the damages.
