stclairriverblaster
- Jul 8, 2007
- 7
hello all. new to the forums. and had a couple questions. i have a 1979 checkmate with a 1979 200 hp mercury outboard engine. perhaps you can awnswer a few questions
A. i have 120 psi of compression across the board is this fine?
just bought the boat... it needed a stator. so i installer per the manuals instructions. and took the boat out..
boat ran fine for about a min of full throttle. then started bogging down. and would eventually stall. once i got it started back up. usually 45 seconds to a min later.. since it would have diffuculty starting almost like its flooded it would fire back up and would be fine again for a couple about another min of full throttle then it would happen again. but if i were to cruise at about half throttle it would be ok..
please help.. whats goin on. i have a feeling its a fuel issue.. since the stator is new.. and im getting spark. to all cylinders.
i am running 50:1 ratio in the fuel and its yahamas half synthetic formula
is there anything im doin wrong?
