Re: Motor blown because of VRO
The service manual goes into how to check oil usage by using a low reading pressure guage, and a lenght of clear plastic tubing (1/4" ID) tie strapped to a 12" ruler. The guage will give a jump every time the pump pulses. The oil in the clear tube should drop 1" every four to six pulses. Keep in mind you are running on pre-mix here. The clear hose is joined to the oil inlet nipple, and the clear tube filled with oil. Here is a nother thing you may want to check. If you have a boat with the oil tank out of sight, such as in a transom well, and the boat was out in heavy rain uncovered, that oil box will show full, or nearly so, because it has possibly been flooded , and has several inch's of water on the bottom. I have run across this twice. When you say your engine is shot, do you mean through out the whole engine, ( crank, rod's, bearing's, piston's) as a total oil failure would cause? You said you tested the engine warning system, the repair shop should have done that.
