Re: Motor Alignment
Above is always better but how high depends on the prop and bottom design. A SST will run higher than an aluminum, a Raker higher, a Stlietto higher and a 4 blade even higher. And make sure it's in the center of the keel not necessairly the center of the top of the transom.<br /><br />Good luck!
