PowerAddict
- Aug 8, 2007
- 418
Probably some easy ones.
1. What am I doing wrong running it on muffs? with the drive off and water in the hose coming through the transom, it sucked up water just fine. With the muffs on the lower unit, I have no water coming out the exhaust? Either I'm doing something wrong, or there's a problem with the drive right?
2. The manual says that the outdrive takes 2.2L of gear oil. So this should not spill out the vent hole right? I put about 2.5 quarts plus a little that was in the lower already and it puts it the very middle of the dipstick on the vent screw. This sound right?
