DJK555
- Sep 19, 2017
- 28
1994 3.0 L Alpha one Gen 2. Recently bought a boat that is in pretty decent shape but the trim gauge is not working. I’ve searched past threads on this and other forums and have a fair understanding of the operation. All components appear to be good. The sender was replaced at some point. It was full of grease but has been cleaned. The contact strips and rheostat are good. The wires are visually good, at least those in the harness that comes attached to the sender.The back of the gauge is not corroded. There is current to the back of the gauge with key on. The gauge is pegged at full up, actually off the scale.
Can anyone one provide a test sequence and desired readings for the system. I don’t mind replacing components but would rather diagnose with a volt meter than by throwing parts at it.
Thanks in advance.
Thanks in advance.
