Re: More speed, hop up kits? Volvo 5.0 GXi
there are several companies that offer various kits for marine use, none are cheap and most will require a gear ratio change in the drive.
best thing is to keep your current set up well maintained or purchase a larger power plant.
the small block transom shield is good to about 350 HP then you will need the larger big block shield. the SX case is rated to about 450 HP and you can purchase a 425 Hp 8.1 from volvo.
most car mods dont work real well in the marine world as most car mods tend to shift the power curve to high.
big lumpy cams that can twist to 7K tend to not make enough power at low speeds to accelerate a boat. prop speeds,until you go surface piercing, dont like much more than 2500prop shaft RPM.
what kind of RPM is your setup currently running ?
