More serious 3.5a questions, ie Removing powerhead
bchinn
Ok so ive posted two previous questions. First was about changing impeller, second was about adjusting fuel mixture. Both went well and i repaired all that nonsense. Of course the motor still wasn't spitting water. So i go back home and start taking it apart. I took the "head" off, or the part where the spark plug goes, and wow, the previous owner really neglected the motor. The ENTIRE water jacket, was solid. So ive been picking away at it. <br /><br />My question is, i need to take off the lower unit and remove the power head. I removed the six bolts that appear to be connecting the poewrhead to the lower unit but it wont budge. Clearly part of the pull starter is still connected to the lower unit. How do i seperate the power head? I removed the six bolts on the part of the motor facing the control panel, on what i would call on a car the crankcase, and nothing wants to come off. How do i go about seperating the power head?<br /><br />On the bottom of the lower unit i attempted to remove the two bolts that hold the lower part up to the upper part of hte lower unit. Well those bolts were basically just dust as they had been pretty much ate through and the heads snapped off. With those bolts removed and the prope and all impeller parts removed should the lower unit from basically the cavitation plate down come off?<br /><br />I believe the motor is basically totalled. But i figure ill try to get it working anyway. <br /><br />All help much appreciated, <br /><br />Thanks<br />Brian
TOHATSU GURU
Re: More serious 3.5a questions, ie Removing powerhead
The only things holding the powerhead on are the bolts from the motor leg to the powerhead.
bchinn
Ok, so it sounds i am correct in my assumption that it is just that the splines are probably corroded together on the shaft? Because i can move the powerhead slightly around the axis of the shaft, but cannot lift it up.<br /><br />Sound about right?
bigskydrift
Have you tried rapping on the side of the head with a rubber mallet, working all the way around it, may take awhile as it really sounds "bonded"
bchinn
Ok, powerheads off. water jacket has been scraped clean, gasket kit and impeller is on the way. Looks like its gonna be fine.<br /><br />Thanks for all the help<br /><br />Can you provide torque numbers for the 6 bolts that hold the crank case on, and the 6 bolts that hold the powerhead onto the drive leg?<br /><br />thanks<br />brian
bchinn
Also, should i put any oil into the crank case area? <br /><br />brian
