79 Searay, 228 Mercruiser , swapping '98 5.7<br /><br />Thanks for your help so far, now my question is,now knowing i have an early alpha type outdrive,and not a TR, which bell housing is needed, the '79-228, or the 98 5.7 , and is the older gimble set-up ok?(the '98-5.7 was hooked to a Bravo-3) Also,any tips on utilizing the late model manifolds and engine mount seapump with the old outdrive, and it having an impeller type pump?
