Thanks to all for the earlier thoughts, I could use a few more.
To recap...a new to me 89 225, has the nose cone water intake. It hadn't been used for a couple of years, but was obviously well maintained by a loving boat owner. Stored properly from the sounds of it.
First test run, started right up without choke and in neutral position, but quickly over heated and low power (no better than 2500 rpm). No water from tell-tale.
Compression checked out about 90 in all cylinders +/- 2-3 psi. Sparking on all 6, although I did not perform the 1/4" spark jump test that I read about hear.
I dropped the LU and replaced the impeller. Two new thermostats.
2nd test run, very hard starting. I had learned about the push in choke by then, and I tried it. It took many (30 tries) to get it going. I ran it for 15 minutes at idle and up and down a bit in neutral. Good steady water output from the tell-tale, but still approached "white zone" on the temp guage. I shut it off, and would not restart. The starting gear would seem to drop off the flywheel before I would get even a sputter, lots of strange noises. Ran out of time, went home.
Lots of advice to rebuild the carbs from this forum in a boat that sat for a couple of years, and I thought this was reasonable.
Rebuilt all 6 carbs, cleaned orifices, etc. By the advice of my local evinrude guy, I disconnected the wiring harness to the VRO pump, drained the tank and added new gas and oil. Changed all fuel filters. I could hear the float bowls filling nicely. Brand spanking new battery.
Last test, I tried to start with a little throttle and held choke in for 5 seconds. Very hard starting, would smoke like crazy out of the air intakes after each attempt. I put the throttle in neutral, and stopped choking it. Eventually got it going. LOTS of smoke for a couple of minutes. Really...alot. This cleared up nicely though, idled nicely. Temps climbed right up to the "hot zone" when I goosed the throttle a bit, but this came back down and seemed to stay there. I figured we could slide off the trailer for a little test run.
No power in reverse. Idle speeds only. We goosed the throttle and for the first time since I've owned the boat ( about a month now ) got up on plane and had some fun. At around 4,000 RPM steady alarm would sound, stop quickly when I throttled her back a bit. Throttled back up, got the alarm. The water temp actually was at the lowest I had seen, I think the nose cone set-up likes the speed. Anyway, I ran out of time, and headed back.
The issues...
1- starter gear drops off flywheel prematurely, before even a sputter.
2- hard starting...I think it doesn't like choking...lots of smoke after starting
3- no power in reverse
4- alarm at high speed with cool water temps...VRO is disconnected.
Thanks for taking the time to read this, and all thoughts are welcome. I'm learning alot here...just not enough yet!
Mike
The issues...
Mike
