Ron Whitnwy
- Aug 16, 2001
- 8
Ok guys, here is the scoop. I filled the tilt unit up with fluid and it did lower very slow but It was lowering and the motor sounded about the same in both directions but it sounded like it was sucking air or had air in the lines when lowering. This ia when I noticed it was leaking all of the fluid out as it was lowering through the side screw (I think it is a manual valve to lower the unit incase of power failure) when looking at it closly I can see that part of the o ring is bad and it is leaking around the screw. Is this something that I can replace without taking the motor off or do I need to take it to a boat shop? The o ring looks like it is held it place with a snap ring. I feel if I can replace this and keep the fluid it it will work fine. If it is something that I can replace how do I go about it? Thank you for all of your help, its greatly appreciated!<br />Ron
