New guy here. After searching the net for answers to questions regarding the Yamaha outdrive on my '93 Ebbtide (w/GM 4 banger)I've found some pretty good advice here. Some funny stuff too, but you know what they say about opinions.<br />Now I'll cut to the chase. What started out as "gettin' the boat ready in time to take the kids out to the river for spring break" has grown into BOAT. Bring Over Another Thousand. Besides the usual clean-up (it was put to bed for the winter nice and clean, flushed, new oil & filter, plugs, a little sta-bil in the tank, batteries out, etc. I knew I needed to check the carb that I should have in October. It was like I expected - carb rebuild because the accelerator pump was gummed up...OK, I can handle that. Starts like a champ...run it through the gears....what's that noise?<br />Turns out to be the Gimbal bearing. Hmmm, what's with the rusty water in there? Bellows looks fine. Cracked gimbal housing!<br />Small crack, but enough to let enough water in to seize the bearing.<br />Question....I really don't want to a)buy a new housing, and b)yank the engine in the process<br />so do I weld the aluminum housing while in place? Or, do I try something like JB Weld?<br />From all that I've read since I registered, this sounds like a question for Capt. Ken. Suggestions?<br />Thanks.
