wright brothers
Thread starter- Joined
- May 2, 2010
- 6
Hello. I read for three days and found info. Now joined to ask questions.
I'm not a boat tech, just a country boy.
'58, 7.5hp, green, old. Parts motor too.
#s taken from tiller handle tag
Model # of top end, 571 58781
Model # of lower unit 571 58751
I swapped out lower unit, impellor looked good to me, serviced lightly to see if it would fire. It started right up.
Number one concern is if the cooling flow is right. How do I check for this?
There's a sticker says coolant flow indicator, but baffles me as to where to check. I removed pipe plug from bottom of head and water squirts intermitantly but not steady stream.
My concern is if I seated the copper tube into lower area properly. How hot should this engine run?
I have other concerns but that is the major one on my mind. Thanks.
