I need some clarification. I believe I am making this too difficult. I have read that the floats in carbs need to be parallel with the bowl and I understand that but at what level. My Johnson 55hp does not give me a measurement but suggests a gauge that I dont have. If anyone can tell me at what is the space between the edge of the carb and bottom of the float. I have rebuilt the carbs and found that there is gas seeping at the gaskets, I am planning on removing the carbs rechecking everything and putting it back together. The boat starts when the warm up lever is on full. Then it dies out when the lever is placed back down. The boat will not get up on plane.
Just an FYI, power pack is new, one coil is new, other coil tested and is ok, spark is good and compression is 165 on one cylinder and 175 on the other. Any ideas in direction would be appreciated. This forum is my boating encyclopedia.
