My timing sticker is a little bit chewed up and has some paint overspray on it. The only part of the sticker I can make out is the area between -12degrees and 12 degrees. Am I missing any other information on it? <br />Assuming I have a dial indicator I should: 1.accurately set the piston head .464" recessed from TDC, 2.Set the plastic indicator even with the circular indentation on the flywheel. 3. Check .464 mark on sticker which should now line up with indentation and pointer, 4. When I roll flywheel forward and TDC on sticker is lined up with the plastic pointer, Piston should be at TDC. Is this correct? I'm guessing that the .464 mark is used to line up the timing sticker while applying it to the flywheel surface.
