More 25hp Mercury carb questions
19Bill74
Ok, I have two questions left before I should be able to try and start it.
1st. The idle wire, wasn't hooked up to anything under the flywheel. It went through the plastic arm that moves back and forth. Should I turn it so it goes in the middle if that arm? Or, does it hook into a small hole in the metal plate up in there?
2nd. I loosend the bolt to get the linkage away from the carb and roller so I could get the carb off and out. I didn't realize that bolt was part of a cam setup and now I'm not sure where it was and not sure how to adjust it to where it was or line it up. Rookie mistake. Any help would be great. Thanks
