Modifying 20in shaft to 25
crazy charlie
Hi guys ,I have this also posted in Johnson-evinrude.because i really need help fast.To get right to the point,I bought a 95 150 Rude ocean pro with a 20in shaft that I am putting on my 17ft Mako(yes I know its a little large) and have discovered that I need a 25inch shaft .I bought the 95 150 to replace my 82 115 Rude from a private individual so return is not an option.I bought the wrong size motor.What is involved in an extender kit ,labor and parts cost and is it recommended.The other post has more detail.Charlie
Bass Runner
Re: Modifying 20in shaft to 25
Is it possible to cut down the transom or is this a glass boat? if not I think it would be cheaper to go with the bolt on transom extenter like they use on bass boats for the big motors. Just a thought.
crazy charlie
It is a glass boat and I surely dont want to modify the transom.There does not seem to be a clear cut answer.I may sell the motor I bought for it and start all over.Charlie
kcole683
Try this link,the company is in ohio and makes extensions for just your situation. You will have to call or write. There is no online pricing available at this time<br /><br /> Outboard motor extensions
crazy charlie
Thanks Sparky,I called them but it seems they are closed for the week.Do you know any Evinrude parts houses I may be able to check with.Charlie
