Re: model # and serial # again...
Welcome to Iboats, Weltaned!<br /><br />For starters:<br />Johnson QD-22:<br />Year: 1961<br />HP: 10<br />WOT RPMS: 4500<br />Displacement: 16.6 cubic inches<br />Cylinders: 2<br />Weight: 70 lbs<br />Gearcase ratio: 13:23<br />Spark plugs: Champion J4C gapped at .030"<br />Lower unit oil: OMC/BRP 'HiVis' or equivelant 90 weight outboard gearcase oil<br />Fuel/Oil mix: 24:1 87 octane gas to TC-W3 rated outboard oil<br />
'61 Catalog<br />
From the Old OMC Site <br />
'58 10hp Evinrude site.<br /> <br />Ok, now you want to know about that long plate that's just above the cavitation plate? There is supposed to be a cover there. That passage allows water from the water pickup (directly behind the prop) up into the water pump. You can see it pretty well in this picture of an evinrude:<br />
Click here. Or here Or here. <br />As you can see, it has a few holes in it. That is to allow excess water that's been shoved into it at high RPMs by the propeller to bleed off. <br />Since putting a cover over it kept the pump from pumping, there must be something obstructing the water inlet. It should just have a screen over it.<br />If you run the engine without that plate in place, it will not get enough cooling water at speed.<br />Hope this helps!<br /><br />EDIT: Ooops! Somehow I read 'Left Hand Side'.
<br />That window is there so you can disconnect the shift linkage behind it. The cover that goes over it is simply that - a cover. If putting the cover on caused it not to pump water, then either you didn't have it in water deep enough (it must be over the seam between the lower unit and midsection) or your water pump is just about worn out. No big deal since they're to be replaced every couple years and only cost a few dollars. You can do it yourself with a service manual and some simple tools.
