ParallaxBill
- Aug 27, 2006
- 341
This one has got me stumped so far so I figured who better to ask than you guys.
I am in the process of replacing my water pump with a sierra kit #18-3317 pump housing kit ( replaces Merc #46-57234A3). For my 73 Glassmaster 165 Mercruiser L6
My problem is that there seems to be no upper housing replacement seal like the one that is in the new bottom housing and in my original upper housing. The only seal I see is the one that slides down on top of the housing just like the one I took off. There is nothing to seal the actual housing at the top. My kit's bag was sealed when I got the kit and inventoried the new parts.
Is the seal missing? Or does it no longer use an upper seal beyond the round rubber seal that slides down the drive shaft to rest against the upper housing? The latter just does not seem likely to me.
Help me out because I want to get back on the water ASAP and need to know if I need Iboats to send me the missing part if it is missing.
Thanks much,
Bill
Thanks much,
Bill
