Mixing Grease Brands
waterbill
Two types: 1) Lubrimatic boat trailer wheel bearing grease(blue-green in color); 2) Pennzoil boat trailer WB grease(green). If my hubs are packed with grease #2, is ist ok to add some of grease #1?
bruceb58
Re: Mixing Grease Brands
It isn't the color that is important but the base material of the grease. Certain bases shouldn't be mixed.
bruceb58
It looks like they are both calcium sulfonate complex bases so they should mix ok.
studlymandingo
A wise man once said: "any grease is better than no grease at all"
4poco
not trying to rob this post, but what can be mixed and what cant ?
lithium and calcium base does it mix ?
roscoe
grease will break down, become runny and leak out. It can't lubricate if it leaks out.
