Missing Flappers and performance issues
shaps1001
Hi All. I have a 1993 OMC Cobra 5.0 that will only get to 3500ish rpm at WOT. After checking pretty much I everything else, I read about problem of broken flappers blocking the exhaust flow. I had actually seen the bare in pins in the Y pipe when I changed the risers but I didn't realize that there was supposed to be a flapper there.
I took it apart again but I couldn't see the missing flappers from the top. The outdrive is due for service anyway so I plan to pull it to look for the flappers and replace the bellows/gimbal bearing.
My question is where in the outdrive do the flappers usually end up? Can they can make it past the exhaust bellows? If so will I have to open up the outdrive? Where else do I need to look?
Randy J
Re: Missing Flappers and performance issues
underneath the exhaust water hose with the cut outs they can go all way into the foot and usually melt & jam up against the shift rod can be fished out with thru the tube with long nose needle pliars
shaps1001
Does that mean I will need to open the outdrive case?
Randy J
nope lay under boat and look up where very bottom hose is will see slits gently take a big flat blade screw driver and a real good work light and just gently look inside of hose toward the foot where it goes more n likely will see the old flappers, most of time therye a melted mess will have to have the drive raised all the way up tho and be sure to have it secured for safety, i put a rope on it and tied off to ski hook at back of boat, i know it dont come down on its own etc but id rather be safe than hurt lolo
shaps1001
Flappers were definitely my problem. One was completely blocking the exhaust bellows and the other was in the outdrive.
