I have what I believe to be a 1989 200hp Johnson and I have searched all over the mounting brackets with the engine in every position..trim.. tilt...turned etc and find no sign of any plate or holes from where it might have been. On top of the starboard side are two lines stamped into the engine bracket. First line reads"187400" and the second line reads "11JN1". Are these just part numbers for the bracket? This motor is mounted to an Armstrong outdrive transom bracket and perhaps this required a different motor mount sytem and hence no more data tag?? Anyone have a specific location to look for the info tag or any other way to positively identify the year and model?? I know it should be simple but......help!
