I recently purchased a boat and it has a 1977 or 78 45hp Chrysler outboard engine in it model number 457HD. The first time I had it out it bogged itself down and killed itself. I got a tow back to the dock and I found out the plugs were carbon fouled. I replaced the plugs with hotter NGK's. It still fouled out the plugs. Aftet futher investigation I noticed the engine had a slight miss to it and the bottom spark plug fouled a lot quicker than the top plug. I have done a compression test and they both were around 110 lbs. I also looked at the points and one was black so I am going soon to replace the points and condensers. I am wondering if the coil pack for this year engine goes bad. I also am wondering if the timing cound play a role in the foul of the plugs. Any help would be greatly appreciated.
