GarySequim
- Mar 30, 2021
- 9
I pulled my boat out to run it in the driveway for the first time this year. It started fine and water was exiting the stern drive as it should. And then a giant white cloud blew out of the exhaust, unaccompanied by water. Steam, I hope. I quickly shut it down and pushed the boat back into the garage.
I pulled the stern drive apart and found that the nearly new water pump and impeller were still fine and there was no debris in the water passages. I then pulled the exhaust elbow and found no water shutter valve, only the metal rod that used to hold it.
Sooo ... I rented a fancy bore scope and checked the exhaust from inside and outside the boat. I could find no trace of the missing shutter valve. I hope this means a previous owner took out any pieces and forgot to install a new shutter. But, I wonder if the pieces somehow got forced up the exhaust into the manifold? This seems unlikely; I just hate to put everything back together and find I missed something.
My next step is to trace the flow of sea water to see if I can find a blockage. It seems like the boat's problem should be the missing shutter valve, but it couldn't have disintegrated in a few seconds when I fired up the motor in the driveway.
Ideas for how to further troubleshoot this will be gladly accepted. Should you ever need help with a 105 series Alfa Romeo, I can help. Otherwise, I'm pretty much useless. Oh, not entirely useless. I've attached a copy of the sterndrive repair manual I put together for my own use, as all the others are disorganized or leave out stuff that's important for amateurs like me.
