Misfiring Suzuki outboard DF 70 4 strokes
philoudent
Hello everybody, I'm new on this forum and i hope you can help me with my engine problem
I took a video, the sound isn't perfect but you can see what happens
https://youtu.be/7QJgCbctHsU
Misfiring starts at 5 minutes running, no matter the engine rpm. they stop when i slow down at 3000 rpm. There is none alarm
The motor is a second hand, built in 2008.
Trying to fix it we :
- did computer diagnosis ( no failure)
-changed all filters (oil, air, water separator)
- put additives in fuel like water remover and injectors cleaner
- cleaned fuel injection rail and injectors manually
- controlled high pressure fuel filter
Despite it none amelioration
Does anyone has an idea ? We're trying to think to everything, temperature, pressure, electricity, defective part ... Our local mechanic is thinking about a bad contact in the vapor separator tank. We're waiting for a new cable ....
Thanks for your help
99yam40
have you tested to make sure the alarm system works?
Could be it is overheating and going into RPM reduction after 5 min
I have no idea how you controlled high pressure fuel filter
and I do not know what amelioration means
clanton
Check the shift switch. If out of adjustment, will limit rpms to app 3000. Check fuel pressure at 3000 rpms, should be 46 lbs.
philoudent
Hi ; thanks for your help. Things get better today after i repaired the primer pump. Misfiring started at 5000 rpm's. There was a vacuum leak on the pump. Tomorrow i'll replace it. I hope the problem will be resolved
Sorry for my English, i'm French:joyous:
Ps; by amelioration i meant improvement.
I'll give you news tomorrow
