I have a 23 foot single axle aluminum trailer with somewhat of an oddity. The axle does not appear to be centered inside the fender well. In fact, there is about three inches difference in the clearance between the front of the tire and the fender skirt and the back. As a matter of fact, you have to actually tilt the tires a bit to get them to clear the fender wells. So far this has not been an issue when trailering, but it is certainly noticeable.
I was thinking about simply loosing the u-bolts that connect the tube axle to the leaf springs and centering the axle, but I have never needed to do anything like this before and was unsure if there were any issues to take into consideration or be made aware of. Thanks as usual for any insight or guidance.
