Re: Minor XP help?****Whoppee!!****
boomyal, <br />Go to start, programs, powertoys for windows xp, tweakui. If its not there, go to the instructions i wrote at the end of this message, then when you've got that done, come back to this point.<br /><br />Then on the left hand side of the TweakUI window, click the little "+" beside logon and you will see "Autologon" pop up below it. Click on it!.<br /><br />Then over on teh top right, tick the box that says "log on automatically at startup"<br />Type your user name into the white box<br />If you use a password to log on, you need to click on the "set password" button and put your password in twice.<br /><br />Then click ok. Next time you restart your pc it will automatically log on!<br /><br /> Instructions if ya can't find the tweakui thing: <br /><br />Go to start, search, files or folders.<br />Type in TweakUiPowertoySetup.exe and click search.<br />When you find it, double click on it and it will install itself and then you should be able to find it by going to start, programs, powertoys for windows xp, tweakui.
