What are you looking for, as far as good-bad-ugly?
I have a MK 70# Vector 3X and like it, almost everything is a plus on this TM, beefy transom bracket, tilting/extending handle, maximizer digital technology.
2 downsides to this motor that I have experienced:
- The trolling motor has the 3X steering that takes some getting used to. Turn the handle a little and the motor turns a lot. If you're used turning 90* hard to port to turn quickly, with the 3X motor that would have you going backwards in the opposite direction... The TM has a direction pointer on the head, so you can see where the motor is pointing, but I found it a pain to look at the arrow.
- There is no "reverse" on this TM, so you can't flip it into reverse to have the prop spin backwards, to blow weeds off the prop. You can spin the TM around 180* so it moves the boat backwards, but the prop does not spin backwards. I haven't had issues with this, but could see how it could cause issues if the prop got totally fouled with weeds, IE: stuck in a weed bed.
You have the get the "feel" for this TM and pay attention to the direction the boat is going, opposed to where the TM handle is pointing.
I modified the shaft lock on the TM so the handle sits off about 45* to starboard (directly towards the rear center seat of my boat) when the motor/prop is pointing straight forward. I can steer the boat full left and right by 60* of handle travel,,, which is easy to do seated in the center back seat of my boat. (see pic) Works slick in my set-up.
