Minn kota prob
St3v3np
I habe a 1990 s minn kota 37 lbs thrust 4 inch motor does anyone know which prop will fit. I bought a mkp7 the holes too small the mkp4 looks right but no one shows the size of the hole
gm280
Is there any way you can correctly drill out a perpendicular center hole to allow it to fit? Not seeing either the trolling motor or prop in question, I have no ideas what your looking for. Post a couple pictures so we can see what you are dealing with. Pictures always helps. JMHO
St3v3np
I would put its not letting me post pics the problem is its not fitting over the shaft where it bolts to the motor the prop has a pilot hole that looks like 3/8 inch the old prop looks like its 1/2 inch. I dont know if i can drill it out the hole without screwing it up i dont have a drill press
Silvertip
Honorary Supreme Mariner
Measure the shaft diameter and then head to your local sporting goods or outdoor store and measure the hole in the various replacement props. If the motor has a model & serial number tag, that should help get the correct prop, Just because it's a MK prop does not mean it is the best prop for the motor. Those are usually optimized for each motor.
