minn kota has only one speed
caphank
Hi guys. I have an old minn kota 3hp motor w/ maximizer system. There is no foward thrust until it reaches 'HI'. Reverse works fine. Do I need to replace the variable speed switch/handle assy?<br />This is the unit that has all the wires going in and and out of it. If so where would be a good place to order one? Thanks. Caphank
tunfdk
Re: minn kota has only one speed
Caphank,<br />Did you ever fix your Minn Kota problem? I have an '88 3HP MK, no maximizer. I lost reverse had forward at full-speed only. Then it went completely. The board is no longer available & the switch is $40, but I don't know how to test the switch.<br /><br />Thanks
